AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
How do I change MAPIOPTIONS with VBA or LISP
3 REPLIES 3
mkaandorp
659 Views, 3 Replies
Where can I find the variables which you can chooce in the dialog of MAPIOPTIONS so I can change then with VBA or LISP.
x-Greetings,
Marco
3 REPLIES 3
It depends on what exactly you want to change. Basically, map keeps it’s variables in the registry. You need to find a proper one.
  (setq ImgDetach(vl-registry-read (strcat "HKEY_CURRENT_USER\\"(vlax-product-key) "\\Applications\\AcMapRastUtils\\Options") "ImageDetachMode"))
  (vl-registry-write (strcat "HKEY_CURRENT_USER\\"(vlax-product-key) "\\Applications\\AcMapRastUtils\\Options") "ImageDetachMode" 1)
Thanx, that is what I was looking for.
I added that to my acaddoc.lsp but i feel like I have the formatting or something wrong although it's not erroring it's also not changing the registry...
;sets the mapioptions so that shift left click doesn't pick an image
(setq ImgDetach(vl-registry-read (strcat "HKEY_CURRENT_USER\\"(vlax-product-key) "\\Applications\\AcMapRastUtils\\Options") "ImageDetachMode")) (vl-registry-write (strcat "HKEY_CURRENT_USER\\"(vlax-product-key) "\\Applications\\AcMapRastUtils\\Options") "ImageDetachMode" 0)
replace "imagedetachmode" with "ShiftLeftClickSelectMode"
John Hammer, LA/CADD Manager
”Boost
