AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
192 Views, 3 Replies
help
Im doing a offset of a road centerline within 3D maps, and to me the offset line ends up 1 state away. Are my settings set wrong, or what?
thanks.
3 REPLIES 3
Most likely the map is in a lat/lon coordinate
system. Either convert it to a state plane system or set the offset distances
down into the decimal ranges.
Im
thanks.
how do i set the state plane system?
dmo1205
From the AutoCAD Map 2009 Help menu
To assign a coordinate system to the current drawing
Click Setup menu Assign Global Coordinate System. At the Command prompt, enter ADESETCRDSYS.
In the Assign Global Coordinate System dialog box, under Current Drawing, enter the coordinate system code for the current drawing
If you do not know the code, click Select Coordinate System. In the Select Global Coordinate System dialog box, select a category. Select from a list of available coordinate systems. You can also search for coordinate systems by code or description using the Search box. Click Properties to view the properties of the selected coordinate system.
Click OK. Edited by: dmo1205 on Jun 16, 2009 6:36 PM
”Boost
