Hello!
I may get quite "nasty" task.
I have about 500 parcels and need to plot each on indiwidual plan.
the parcels are in shp file and each one has reference number.
what I'm doing now is: in paper space I have my title block (with project name, etc), I query the parcel number, move parcel in viewport, scale viewport and plot the drawing. I use the same layout tab, I just querry the new parcel and move it in viewport.
I would have to repet it more than 500 time which I think would take me about a week.
Is there a easy way to do that?
Script, lisp, map book....anything?
Maybe somebody has an idea how to simplify or speed the process (except clicking the mouse faster
I would appreciate any help!
Ania
Lets say LISP or ANYTHING ... imho a short tool has to be done. Question is what type of programming language do you know, and how far are you able to solve that by yourself?
Or ask your dealer or support-company if they can do that for you.
- alfred -
Yes, i'm a lisp newby. I can create/update/adopt simple lisps.
I will contact my dealer and ask them for help if it's not that straight forward.
Thanks for reply,
Ania
>> [...] ask them for help if it's not that straight forward
No, as I don't know any standard-function that can do that it has to be created for you ... and this can't be straight forward as this depends from your data-structure.
Just to have an imagination:
it should not use more than a few hours to have that macro/tool finished.
Good luck, - alfred -
>> and could share their ideas
Ok, what would I do:
Prepare a layout, that
Next prepared the parcel-borders and -labels
...that could all be done by the SHP-stylization
And then the tool will do:
get a list of parcels to plot
HTH, - alfred -
How to zoom to center of parcel without changing the cale?
I have already filtered the parcels that are affected by search corridor and there are 556 parcels to plot (I think it would take me about 41h!).
To filter parcels (in order to show only one on a plan) I use Query < ID = 'value from a list' > can I add some expression so it centre the parcel?
Thanks a lot for help! 🙂
E.g. with PAN 😉
Or _ZOOM and option _CENTER (look >>>here<<< for details to the options)
- alfred -
ah, yes.....I thought there is something I could use as expression in my query.
ah.....my hand is already aching
