"jdugg001" <If
href="mailto:jmduggan@hovac.com">jmduggan@hovac.com> wrote in message
href="news:f0ab145.-1@WebX.maYIadrTaRb">news:f0ab145.-1@WebX.maYIadrTaRb...
you can export a database file in map3 to a shape file but then the same file
cannot be exported in map5 AND then you save back to map3 and the file
transfers again as if everything is okay but trying back in map5 still doesn't
work...where does the problem lie.
Thank you -
John
"jdugg001" <Hi
href="news:f0ab145.1@WebX.maYIadrTaRb">news:f0ab145.1@WebX.maYIadrTaRb...
Wendy,
Thanks for responding. My problem has been semi determined to
be a corrupted file, however i fail to see the logic in that answer. I am able
to save my map5 drawing as a map3 drawing then i can open that drawing in map3
and export to a shape file, the process works completely database key and all.
I then reopen same drawing in map5 try to export and map5 thinks the database
is changed or moved, it must really think that it is just changed since
exporting only the key data will actually work. where is the real problem and
whats the work around? other than continue to transfer back to map3?
thanks
John
"jdugg001" <I
href="news:f0ab145.9@WebX.maYIadrTaRb">news:f0ab145.9@WebX.maYIadrTaRb...
am sorry if I have offended anyone here, but it’s frustrating when your
upgrade has downgraded some of the features I use the most. Sincerely,
John
