When I hatch a closed polyline that has an excepcionally large number of points, by the option "sorting element", the solit filling color do not fill all the space. How can I solve it?
Edison Ramos Tomazzoli
Maybe the border is twisting somewhere, señor.
Hello
Could you give us a copy (with WBLOCK) of your special PLine ?
Patrice BRAUD
Thanks Olga, but could you post the line with an older vertion of Autocad? ...autocad 2012... Tkanks.
Edison
Hello
The DWG from Olga in DWG2004 format ...
Is it OK for you ?
Patrice BRAUD
Thanks. The problem was not solved (see in image that the closed polyline was not correctly filled by the hatch color). I think that this a specif problem of the Autocad software that is not able to work with polylines with bigger number of points. Think that others softwares, like Microstation don't have this problem. What do you think about this?
Edison
Dear Olga,
Thanks. I do it, but the error remaind (see the figures). I need fix it to conclude a big map. Could you resolve this problem for me?
Santa Catarina University, Brazil
Dear Olga,
Dear Olga,
Thanks for your solution, but Idon't know this terms. Whati is SDF? And FDO provider? How can I do it? If possible, send to me the polyline fixed.
Edison
