AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
HATCH WILLNOT PRINT IN MAP BOOK
2 REPLIES 2
teresaneal
423 Views, 2 Replies
I have some hatched areas in my template for a map book. It prints fine from the dwg file but when I create a block and put it in the layout and save it as a template. The hatch does not print when I plot the map book. Anyone know what I've messed up?
Tags (2)
2 REPLIES 2
phil_borycens
in reply to: teresaneal
Hi Teresa,
The only thing I can think of to try is to go to the Layout that you're seeing the problem, double-click inside of the viewport, and pan&zoom until you get to where you want.
Beacuase sometimes, with these Map Books, it seems that the Layouts they automatically create are not centered.
I do not see any issues with a BLOCK being made up partially of a HATCH -- that works fine for me...
Let us know what you find 🙂
Phil Borycens
phil_borycens
I forgot to mention another related post. Not sure if you came across this in your research...
http://forums.autodesk.com/t5/AutoCAD-Map-3D/Map-Book-Problem/m-p/3142762#M34774
Phil Borycens
”Boost
