Once upon a time (still true?), if you actually SCALEd a hatch object, the
scale property became 'broken' and would act as you're describing. I don't
know if that's still the case or not....sounds like it may be.
wrote in message news:4923857@discussion.autodesk.com...
I have two drawings with the same hatch. The LTSCALE in both drawings is 50
The hatch scale should be 150 for ANSI31 hatch type and that is how one
drawing is, but in the other drawing I have to have the hatch scale set at
3000 to match the other drawing. If I copy the good hatch out and paste it
into the drawing with the wrong hatch, then match the properties, everything
is the same, but the hatch visually doesn't match?
Does anybody have any ideas? The units for both drawings is also the same.
