AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Hatch lines weight
3 REPLIES 3
Vasily_BC
911 Views, 3 Replies
Hatch lines weight
Is there a way to control weight of line for hatch?
I'm trying to make some style for number of areas and when I do hatch on a paper it's almost invisible because it's weight!
Tons of hatch patterns and they all useless!?
Thanks for any suggestions.
3 REPLIES 3
parkr4st
in reply to: Vasily_BC
Drawing objects or data connected; shp, sdf, etc?
lw is accessible in properties or in the layer properties manager.  There is a button to turn lw off and on on dispaly also.
FDO objects in styles
look in help search for plotting lineweights
dave
Vasily_BC
in reply to: parkr4st
Data connect. Shapefile, layer or sdf.
hence_the_name
Hi Vasily,
for FDO features you can apply a lineweight for hatches but not using Display Manager's Style Editor. You need to add it manually to your .layer file.
For a simple hatch (Dash) you need to add the <LineWeight> tag:
<Name>DASH</Name>
 <Graphics>
  <Path>
   <Geometry>M 0.0,0.0 h 0.125 M 0.125,0.125 h 0.125</Geometry>
    <LineColor>%HATCHCOLOR%</LineColor>
    <LineWeight>0.1</LineWeight>
save the layer file (context menu).
Open in XML/text Editor
Add <lineweight> tag for hatch definition
save
load layer into map again.
Good luck,
Rob
http://raumpatrouille3d.blogspot.ch/
”Boost
