Can I, and if so, how do I import a .gpx file into Map? Thanks so much!
Solved by antoniovinci. Go to Solution.
If you're talking about a GPS track, you cannot directly import it in Autocad, so you should convert to DXF/SHP with an external tool, e.g. an opensource Gis.
