AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
.gpx file
2 REPLIES 2
mermerCAD
9398 Views, 2 Replies
.gpx file
Can I, and if so, how do I import a .gpx file into Map?  Thanks so much!
2 REPLIES 2
antoniovinci
in reply to: mermerCAD
If you're talking about a GPS track, you cannot directly import it in Autocad, so you should convert to DXF/SHP with an external tool, e.g. an opensource Gis.
Murph_Map
You can try Mapworks from Dotsoft.
Murph
Supporting the troops daily.
”Boost
