How are you bringing the points in and what version?
If using ODBC data connect you can set a style based on the direction
values, if the points are standard autocad points with data attached (object
data) then you can create a sybmbol layer and set the symbol (a block) based
on the data.
Murph
wrote in message news:5960623@discussion.autodesk.com...
am importing GPS Photo points into a drawing (which I can do) but now i need
to show the direction the photo was taken by symbolizing each point. The
direction value is both in cardinal direction (N,E,S,W, etc..) and numeric
(0,90,180,270,etc...)
