AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
GPS photo points showing direction
4 REPLIES 4
690 Views, 4 Replies
am importing GPS Photo points into a drawing (which I can do) but now i need to show the direction the photo was taken by symbolizing each point. The direction value is both in cardinal direction (N,E,S,W, etc..) and numeric (0,90,180,270,etc...)
4 REPLIES 4
How are you bringing the points in and what version?
If using ODBC data connect you can set a style based on the direction
values, if the points are standard autocad points with data attached (object
data) then you can create a sybmbol layer and set the symbol (a block) based
on the data.
Murph
wrote in message news:5960623@discussion.autodesk.com...
I am using the Points/import command in Civil 3D 2008. I wasn't sure which group to ask, it's one of those that could go either way i guess.
Your reply has got me thinking, I should be able to set a style in C3D for each point based on direction, probably no need to create a block(?)
If you are using the C3D points import then you need to use a C3D point
style/lable style. Map3D can not use C3D points unless you convert them from
C3D to standard autoCAD points.
Murph
wrote in message news:5961008@discussion.autodesk.com...
F.Classon
Hi! We have an extension for doing that. Have a look at it here: http://www.youtube.com/watch?v=zrsJs8c7t9U. It can be used with Civil an Map and is called GeoPhotExtension an will be soon available at autodesk app exchange. Best regards, Frederic
Contelos GmbH - http://www.contelos.de
Blog - http://contelos-gis.blogspot.de/
”Boost
