AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Google Earth Plugin
4 REPLIES 4
matthew.roberts
1444 Views, 4 Replies
Google Earth Plugin
testing the new google earth beta plugin.
have loaded the cui , but i now get
an error box pop on on trying to import the image from google earth.
"Error setting source image name"
any ideas ?
4 REPLIES 4
Happen to have a link to this plugin?
Andrew Schroeder
Reply Syntax?
Command (Uppercase): TRIM, Variable (Italicized): MSLTSCALE, Civil 3D Object (Within brackets): [SITE]
If this solves your issue or answers your question then please hit the KUDO button or mark as an ACCEPTED SOLUTION!
Please support my Idea to revert the forum format to the old one: https://forums.autodesk.com/t5/community-ideas/revert-to-old-forum-layout/idi-p/7917987
in reply to: matthew.roberts
http://labs.autodesk.com/
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
wrote in message news:5315992@discussion.autodesk.com...
Andrew Schroeder
tried again with google earth beta 4
still no luck.
Map3d still giving same error pop up. see attached
Doesn't look like its grabbing the view from google
i'm on windows 2k
map3d 2007 sp2
and google earth beta 4
plugin added ..removed/repaired
still same pop up window on importgeimage
email reply from labs team
seems i needed to 'save' the dwg prior to importing the image from google earth
This has solved the error pop up i was having
Thanks again to Tom
Hi Matt,
Before we dig too deeply into this, could you try two things:
1) Ensure you save have saved the drawing file prior to initiating
the Import Google Image command, and
2) Ensure you have the latest release and/or beta version of Google
Earth (available here http://earth.google.com/download-earth.html)
Let me know if you're still having the problem after trying these two
items.
Thanks for trying the extension.
Tom
Autodesk, Inc.
”Boost
