AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
GetInterfaceObject VB.NET 2011
1 REPLY 1
628 Views, 1 Reply
I Get "Problem in Loading Application" on
     AcadMap = acad.GetInterfaceObject("AutoCADMap.Application")
when i try to run my application on AutoCAD 3D Map 2011 with VB.Net code. can you please help me get this to work?
Also, the Version is 18.1s (LMS Tech) not sure if this helps or not
1 REPLY 1
Alfred.NESWADBA
do you have different versions of Map3D installed?
If you try to add a reference to you project, do you see (under COM) the item "AutoCADMAP" and does this point to the AcMapVbAPI.tlb in the installation directory of your AutoCAD Map3D 2011?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
”Boost
