AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Get coordinates?
3 REPLIES 3
877 Views, 3 Replies
Get coordinates?
Is it possible to get the coorinates of a point in a way I can copy or at least in the command box so I can then move my cursor and still read them?
3 REPLIES 3
gluckett
antoniovinci
in reply to: gluckett
...or simply run the command ID onto the desired point, whose coordinates will display in the F2 window...
in reply to: antoniovinci
I still can't find the Analyze tab (!) but from what I can see that would be an on the fly thing so not permanent enough to copy.
Thanks! I did not know about the F2 window. I would type ID but not be able to copy the results.
”Boost
