Is it possible to get the coorinates of a point in a way I can copy or at least in the command box so I can then move my cursor and still read them?
Solved by antoniovinci. Go to Solution.
Would Tracking Coordinates work?
...or simply run the command ID onto the desired point, whose coordinates will display in the F2 window...
@antoniovinci wrote:...or simply run the command ID onto the desired point, whose coordinates will display in the F2 window...
I still can't find the Analyze tab (!) but from what I can see that would be an on the fly thing so not permanent enough to copy.
Thanks! I did not know about the F2 window. I would type ID but not be able to copy the results.
