I have noticed that the location of the geomarker in my drawing has moved. When I started the drawing and brought in 2 quads of topo contours, it was smack in the middle of the topo. Then I started creating profiles off toward the top of the screen. I noticed that the geomarker is now displayed toward the top of the topo instead of in the middle. But when I scroll over it, it still lists the same lat & long as before. Is this normal?
Thanks!
think of it as a mindless reminder that you're working in a georeferenced coordinate system. if it really bugs you, i think "georefmarker" or some similar command will shut it off.
thepworth wrote:some similar command will shut it off
Yep, the command is GEOMARKERVISIBILITY = 0
