Is anyone else working on gas transmission classification using the "sliding mile" for the building count? If so what procedure are you using. At this point I have run the 660' buffer around the lines added the address/structure point queried to within the buffer polygon then select all the points along a mile of point to get a count. Tedious but working so far. I just wonder if there is a better way.
it showed up earlier here
Don't know if any conclusion was reached
Dave
I can not find that there was a decision made. If there is anyone willing to help with this it would be greatly appreciated. I know I am not the only person dealing with the situation.
