AutoCAD Map 3D General Discussion
Active Member
0 Kudos
Post 1 of 10
Accepted Solution
File Open Dialog Box file name selection
576 Views, 9 Replies
07-31-2012 03:56 PM
When I go to the file open dialog box and start typing in a file name the the file name box it does not show a list of drawings that match the search in the file name box. See below
Alfred,
The problem only exsist on this computer.
We decided it had to be a issuse with the OS (Windows 7) so reformated the drive, reinstalled windows and reinstalled AutoCAD. This took care of the problem and so far everything is working fine. Thanks for you help.
*Expert Elite*
1,210 Kudos
Post 2 of 10
Re: File Open Dialog Box file name selection
08-05-2012 01:24 PM in reply to: dgward
as long as you type while your focus is in the file-name-textbox it's normal that nothing changes in the list of the files.
You have two chances:
  • type e.g. JF-E-005*.dwg in the filename-textbox (then <ENTER>) ==> that will filter the list of filenames matching to the string you typed in ..... or
  • set the focus to the list of files (not to the textbox below) and type the starting-characters to get the files that match the first characters of the filename to the characters you typed.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Active Member
0 Kudos
Post 3 of 10
08-06-2012 03:44 PM in reply to: Alfred.NESWADBA
This did not work. It will not show any files
Active Member
0 Kudos
Post 4 of 10
08-06-2012 03:45 PM in reply to: dgward
I also have reset AutoCad to the default settings and that did not make any changes to the file selection.
*Expert Elite*
1,210 Kudos
Post 5 of 10
08-07-2012 01:23 AM in reply to: dgward
>> This did not work
Which of the two options don't work?
Just to make sure: look to the video I created/I attached and try to follow the steps like I did. If that does not work on your pc, try another pc or another Windows-login-user on your pc. If you have the option to create a video let's see how it does (not) work on your workstation.
- alfred -
Alfred NESWADBA
Active Member
0 Kudos
Post 6 of 10
08-07-2012 07:43 AM in reply to: dgward
Both options did not work.
I watched your video and this is the way it use to work but does not work now.
*Expert Elite*
1,210 Kudos
Post 7 of 10
08-07-2012 07:54 AM in reply to: dgward
and does the problem also persist on another pc or with another user-login on your pc?
- alfred -
Alfred NESWADBA
Active Member
0 Kudos
Post 8 of 10
08-07-2012 08:23 AM in reply to: Alfred.NESWADBA
We only have stand-alone pc's. The other computers with AutoCAD work fine.
*Expert Elite*
1,210 Kudos
Post 9 of 10
08-07-2012 09:13 AM in reply to: dgward
and another user-login on the same computer?
If that makes a difference you could try to export the profile from the other user-account and import it for the AutoCAD in your user-account.
Good luck, - alfred -
Alfred NESWADBA
Active Member
0 Kudos
Post 10 of 10
08-09-2012 02:01 PM in reply to: Alfred.NESWADBA
Alfred,
Post to the Community
New Post
