AutoCAD Map 3D General Discussion
Member
Propertyguy
Message 1 of 6 (188 Views)
Feature cache issue
188 Views, 5 Replies
07-22-2013 06:58 AM
Anyone ever see this message in any of your drawings working in an sdf format
*Expert Elite*
Alfred.NESWADBA
Message 2 of 6 (181 Views)
Re: Feature cache issue
07-22-2013 07:30 AM in reply to: Propertyguy
no, I have not seen that message yet. But searching in www gives that results >>>click<<<, have you seen them?
What I could imagine is that either the structure of the SDF has defects, that could be tried to repair by using _MAPIMPORT and _MAPEXPORT, just to test the data and create a new (purged) dataset (don't forget the attributive data to import/export using Map3D Object Data).
Another idea is to start _MAPOPTIONS ==> tab "System" and clean the cache.
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Member
Propertyguy
Message 3 of 6 (173 Views)
07-22-2013 08:21 AM in reply to: Alfred.NESWADBA
I use the MAPIMPORT and _MAPEXPORT as you have mentioned...I am working in AutoCad 2012.
I do not see a clean cache in the System tab...any idea where I might be missing this
Thank you for reseponding
Greg
*Expert Elite*
Alfred.NESWADBA
Message 4 of 6 (167 Views)
07-22-2013 08:42 AM in reply to: Propertyguy
I can only show a screenshot with the German UI, start command _MAPOPTIONS and try to follow that:
HTH, - alfred -
Alfred NESWADBA
Product Support
phil_borycens
Message 5 of 6 (139 Views)
07-25-2013 07:56 AM in reply to: Propertyguy
Hi there,
We had another user ask about this many years ago...after narrowing it down, it was determined to be an issue specific to a certain machine and Windows user account. So here are some things you might try:
  • Run AutoCAD Map 3D As Admininstrator (just right-click the program's shortcut and launch it that way).
  • If you are pulling files from a network location, ensure that you have full permissions to that folder.
  • Look for existing GWS files in your folder and delete them (it's totally safe to do so).
Let us know if something resolves the issue for you.
And thanks Alfred for your suggestions - the clearing cache might be the solution here! Let's see...
Phil Borycens
philrue
Message 6 of 6 (134 Views)
07-25-2013 03:46 PM in reply to: Propertyguy
I get that message all the time, (using oracle or ArcSDE connections).  What clears it for me, is to go into data connect, and disconnect from the fdo data source or sdf in your case, and then reconnect.  Then on your layer in display manager right click and refresh.  This generally happens when a server reboot has been done or your connection has been lost.  Sometimes this works, sometimes it doesn't.  If that doesn't work.  Go to C>ProgramData>Autoddesk>AutoCADMap3D2013>R19.0>MapCache>find the latest .xml file with the ------------GWS.xml listing and delete it.  You will have to restart Map3D.  Good luck Phil
Announcements
Need installation help?
