I use image insert to attach aerial photographs. I would like to use the FDO raster connection, but I keep having a problem with the raster image losing it's display order. I use "display order" in the display manager and move the raster to the bottom, but for some reason it keeps popping above the line work and I have to keep sending it to the back.
I put images in drawings quite frequently as they change from year to year and we monitor a large number of projects yearly. Is image insert still the quickest solution or is there a way to ensure the image will retain it's display order when I do a data connect?
Don
