I have attached a FDO image and created two differents views in paperspace. One at 1:7500 and the other one at 1:2500. All is good until i want to plot the drawing. The native dwg objects are plotted right but the FDO image is plotted at the same scale in both mviews ??
Thanks for the help.
Michel
what version of Map3D are you using?
What type of raster-file(s) did you connect to? And have you tried it with other raster-formats?
- alfred -
Map 2012 and its a tif file with UTM83-17 coordinate system convert to CSRS.UTM-7N
verify first that you are using the current servicepack (>>>click<<<)
Next try to disconnect the TIFF(s) and use command _MAPIINSERT instead of _MAPCONNECT to get the images referenced. Then verify the plot situation again.
Last but not least try the same situation in a new drawing-file, just to make sure it's not file dependent.
Good luck, - alfred -
Hello
+1 with Alfred
1) Please install the Latest Service Pack
2) When you get some "strange" things with images inserted with FDO technology
Try to use the "standard" technology : MAPIINSERT
Bye, Pat
Patrice BRAUD
Seems to be related to the mviews or something, but would like to find why. I'll keep you posted if i can find the solution.
Same thing happend with FDO WMS.
It seems that the FDO rasters (to my experience with WMS) will not retain the scale set for the Paperspace viewports and are regenerated at full scale.
Have even tested this with the newer MAPs objects and MAPs viewports combination.
For WMS I would believe (but have not investigated this) the request might not properly be build by MAP with respect to the BBOX, WIDTH, HEIGHT parameters.
Maybe similar thing happens for the FDO rasters?
Luc
