AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
FDO connection users
2 REPLIES 2
343 Views, 2 Replies
Is there a way to tell who is connected to an SDF file?  When I try to overwrite an SDF file I get the following error message   "The action can't be completed because the file is open in AutoCAD application.   Currently, I have to email everyone in AutoCad to see if they are attached.
2 REPLIES 2
hence_the_name
don't know if that will work - or a similar tool:
handle - http://technet.microsoft.com/en-us/sysinternals/bb896655.aspx
Good luck,
Rob
http://raumpatrouille3d.blogspot.ch/
braudpat
in reply to: hence_the_name
Hello from France
YES the current FDO into MAP/CIVIL can't give you the Name/Login of an other FDO MAP/CIVIL user
which is already connected to the same SDF/SHP/etc ...
In the Wish list that I have sent last Year to the MAP Team Manager, I was asking for a small imporovment on FDO :
- Connect and Open for Read Only
- Connect and Open for Read/Write which is the current historical FDO "manner" !
REALLY it was technically a SMALL improvment on MAP FDO Technology !
No News, not implemented in MAP/CIVIL 2014 ...
<Humour ON>
So this Year, I will ask for a FDO Connect and Test Infos Command !
with for example, who is ALREADY connected to the same FDO file/Schema ?
<Humour OFF>
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
”Boost
