AutoCAD Map 3D General Discussion
Active Contributor
marknelson
Message 11 of 16 (1,754 Views)
Re: FDO ArcGIS Provider in AutoCAD
04-16-2012 04:22 PM in reply to: anadarko
It is my understanding that ESRI does not have a x64 version of ArcMAP yet.  You can load ArcMAP on a x64 machine but it loads in x86 mode.  I experienced this issue with my FME by Safesoft.  I had to load the x86 version of FME on my x64 machine in order to use all of the ESRI file formats.
We need ESRI to come out with true x64 product or Autodesk needs to create messenger DLL's that can address the issue.  I assume ESRI will eventualy get us a true x64 desktop product.
I can connect to our SDE server from x86 or x64 machines, also.
philrue
Message 12 of 16 (1,739 Views)
04-20-2012 10:47 AM in reply to: anadarko
I don't know if this will help.  At this time I am running Map3D 2013, prior rev 2012, 11...  I have been using the Arcsde connection and Oracle connection to fdo for awhile.  We also have been using ArcMap10 in conjunction with Map3D.  The SDE server is 64 bit, and Map3D is 64 bit, of coarse ArcMap is 34 bit, also using Windows 7 op system.  Out of the box Map3D, I inserted pe.dll(ver10.0.0.6850), sde.dll(ver10.0.0.6850), sg.dll(ver10.0.0.6850) into Program files>Autodesk>AutoCAD Map 3D 2013>bin>FDO.  Then verified the service in Program Files>System 32>driver>etc>services, there should be a row, esri_sde   5151/tcp   #SDE, if not you need to insert one.  In Map3D Data Connection by Provider window, add your Connection name, server name, instance name(esri_sde), Data Store(Default Datastore in drop down), version(SDE.DEFAULT in drop down) and click connect.  Your schemas and datastores should come up.  Check the one you want to bring into Map(note: its slow, I'm currently testing different methods and dlls to help speed up).  Another tip is make sure all data stores on the sde server are registered or you won't see them.  We have multiple GIS folks using these softwares simultaneously.  I will post again if I get the running slow on the sde server fixed. Good luck.
Active Member
potterg
Message 13 of 16 (1,625 Views)
06-20-2012 05:05 AM in reply to: anadarko
To get the 64 bit versions of the dll I had to install the ArcSDE client service (which is a 64 bit application) on my machine and then copy the DLLs over to the bin/FDO directory.  We have all the proper licensing for this since we run the SDE server and ArcMAP.  This worked fine for 2012 but now that I have installed 2013 I am running in to the same problems of not being able to connect to the FDO.  Has anybody else had this problem and is there something different between 2012 and 2013 that I should be aware of.  (and yes I did copy the dll files to the new installation.)
Gene
philrue
Message 14 of 16 (1,615 Views)
06-20-2012 10:10 AM in reply to: potterg
I am using Map 3D 2013 64 bit and connecting to a SDE server.  It works fine.  Did you check if you have an entry in C:\Windows\system32\drivers\etc\services file, esri_sde     5151/tcp      #ArcSDE  ver -Oracle.
Also check
C: Program Files>Autodesk>AutoCAD Map 3D 2013>bin>FDO>providers.xml, verify if OSGeo.ArcSDE.(version?) is correct, if not update version using word pad  or note pad to modify the xml.  Hope this helps.
Thanks Phil
Active Member
potterg
Message 15 of 16 (1,604 Views)
06-20-2012 02:31 PM in reply to: marknelson
I re-checked the files and the information is correct or still in there from my original setup under Civil 3D 2012. If you have any other ideas I would appreciate hearing them. The error messages i am getting are as follows: Failed to open FDO connection Failted to open ArcSDE connection Server library could not be loaded (-324) Thanks again, Gene
Active Member
potterg
Message 16 of 16 (1,595 Views)
06-21-2012 08:28 AM in reply to: marknelson
Ok, I got it to finally work.  I was using SDE:smileyfrustrated:QLSERVER:<servername> which originally worked under 2012 but for some reason doesn't under 2013 so I went back to using 5151:<servername> and am now able to connect.  The 5151 changes based on which SDE I am connecting to which in our case is 5151 through 5155.  Hopefully my pain and suffering will help someone else.
Thanks for the input.
