AutoCAD Map 3D General Discussion
Valued Contributor
1 Kudo
Post 1 of 6
Fatal error when using grip to select obect..
184 Views, 5 Replies
04-16-2012 08:47 AM
Crashes
1,210 Kudos
Post 2 of 6
Re: Fatal error when using grip to select obect..
04-16-2012 08:57 AM in reply to: 40032831983
some questions:
  • What AutoCAD-Map3D release do you have?
  • What Servicepack have you installed for it?
  • Is it reproducable (every time you click an item) or does it appear randomly?
  • What datasource-type do you use? SHP, SDF, SQLite, ....?
  • Where does this datasource com from, what software created this data?
  • Does that datasource contain polygons, arcs, points or mixed data?
  • Have you tried to convert it to SDF and continue that way?
  • Have you tried to connect the data into a new drawing?
  • Have you checked the current drawing with _AUDIT (before and after connecting the data)
Additional info would bve helpful:
a) Screenshot from your crash
b) Data-Upload if you are allowed to show that
- alfred -
Alfred NESWADBA
Valued Contributor
1 Kudo
Post 3 of 6
04-16-2012 10:40 AM in reply to: 40032831983
Program - 2012 Map 3D W/Raster Design SP1,64bit
Workstation - Windows 7 Enterprise SP1, Dell T5500, E5607, 8Gb.
Crashes/Fatal error anytime I attempt to select anythnig using grips.. Blocks, plines, text, anything..
Just started it this morning... Last week everything was great....
1,210 Kudos
Post 4 of 6
04-16-2012 10:55 AM in reply to: 40032831983
try to login to your pc/to your Windows with another user-account, then start AutoCAD-Map .... same problem?
What has changed on your pc since it was fully functional last time? Any updates from Windows? Was there anything installed in the meantime?
- alfred -
Alfred NESWADBA
Valued Contributor
1 Kudo
Post 5 of 6
04-17-2012 06:24 AM in reply to: Alfred.NESWADBA
Tryed that, didn't make any disfference...
Reset the system var "GRIPS" to 0 then back to 1.... Fixed it.. don't know why...
Weird... but not surprising..
Thanks for trying to help!!!!
1,210 Kudos
Post 6 of 6
04-17-2012 06:37 AM in reply to: 40032831983
Thank you for the feedback!
I also don't understand the reason why this helped, but now we know that it's worth to try it! :smileywink:
- alfred -
Alfred NESWADBA
