AutoCAD Map 3D General Discussion
Distinguished Contributor
jessebelcher-tvec
Message 11 of 19 (3,438 Views)
Re: FATAL ERROR: Unhandled e06d7363h Exception at 7c81eb33h
06-08-2007 07:11 AM in reply to: EVRIM
In 2008 you need the .net on the machine for cad to run correctly. So put that back on there. And as far as the error the response I got from AUTODESK was that I was working my machine to hard and that I need 4 GIGS OF RAM. I told the guy that he was crazy. I have a brand new 2.6 dual core with a gig of ram and a 128 mb vid card. He said that I was running to many programs at the same time. And to reinstall .net 2.0 that maybe it had some problems. I reinstalled .net and ESRI. And I still get these types of errors ever hour. Maybe I should just get 4 gigs of ram (crazy)! That’s my rant for the day. Just look at my pic and you will see how many errors i get.
New Member
marisolnarvaez
Message 12 of 19 (3,438 Views)
08-07-2007 11:27 AM in reply to: EVRIM
I cant disable de MAPSKIMAP using the Spanish version of AutoCAD 2007, could you tell me how can I disable it.
Member
JADS_BCS_MX
Message 13 of 19 (3,438 Views)
08-31-2007 08:16 PM in reply to: EVRIM
Try this "_mapskimap"
JohnPM
Message 14 of 19 (3,438 Views)
09-01-2007 01:38 PM in reply to: EVRIM
I uninstalled all versions of .NET and downloaded and installed the most up-to-date version. I do not remember what the fatal error message was but soon after everything ran fine.
John
Member
JADS_BCS_MX
Message 15 of 19 (3,438 Views)
09-02-2007 08:54 AM in reply to: EVRIM
Sorry, The correct way is "_mapskinmap"
New Member
marisolnarvaez
Message 16 of 19 (3,438 Views)
09-10-2007 07:44 AM in reply to: EVRIM
I've do that but unfortunately AutoCAD doesn´t works and i have to reinstall and the problem still present.
There´s another solution.
New Member
axbramboll
Message 17 of 19 (3,438 Views)
05-28-2009 01:29 AM in reply to: EVRIM
This may help you.
It generally happens because of a lack of memory during the zoom operations.
You can lower down the zoom resolution by entering the following command : VIEWRES
The default resolution is 1000 but a 100 is enough when you zoom in or out.
Hope that will help solving the problem for you or the next ones.
EDIT : this should be valid for any Autocad plateform (Cicil 3D, ADT, ....) Edited by: axbramboll on May 28, 2009 8:29 AM
Valued Contributor
vcoleman
Message 18 of 19 (3,438 Views)
05-29-2009 11:29 AM in reply to: EVRIM
I had this error for 2 days. This is how I solved it.
Go to options
then system
then performance settings
then manual tune
Surface set to the second bar
Curves set to the second bar also
at the very bottom you will see Number of tessellations to cache set it to 2
Then ok
Hopefully it will help.
New Member
idris_kurbanov
Message 19 of 19 (660 Views)
unhandled e06d7363h exception at 7600812fh
10-22-2013 04:44 AM in reply to: EVRIM
подскажите че не так у меня кароч была 30 дневка закончилась потом всякие фигневые качал
после устанавливал авто кад 2011 студенческий потом написало что у меня он установлен и я не мог его установить чистил его везде ну кароч было много проблем потом через корень поискал и там несмотря на то что он установлен можно было установить я его установил вначале окло 10 длл файлов нехватало я их в инете искал и закидывал в систем 32 а теперь пишит это
Fatal Error  unhandled e06d7363h exception at 7600812fh
Announcements
Need installation help?
