Hello Daniel,
The only thing that I know of that could cause these errors is if the device
"SMS Virtual Mouse" is loaded an running. Usually the fix is to disable the
service/feature.
Mark Christian
ISD Product Support
"Daniel Asmus" wrote in message
news:D96C5618B17C7D319009C51454F674CF@in.WebX.maYIadrTaRb...
> A pesky error has been occuring more frequently and I have been
unsuccessful
> in correcting it. It has been occuring in drawings that I have had no
> previous problems with. Below is a sample of some of the errors. What is
> consistant is that it occurs during a realtime Pan or Zoom. and seems to
be
> occuring at 332beXXXh. I have resorted to saving after every 4 or 5
> commands. When the error occurs, I am able to save the file under the
> _recover option and open it successfully and audit the drawing. Audit does
> not return any errors. Any help or ideas??
> Thank You,
> Daniel J Asmus
> Computer Aided Designer
> Saint Francis Medical Center
> Cape Girardeau, MO 63703
> Phone: 573-331-5870
> Fax: 573-331-5034
> Email: DASMUS@SFMC.NET
> FATAL ERROR: Unhandled Access Violation Writing 0x803cd Exception at
> 332becebh
> 02/04/2003 at 11:14:14.671 Drawing: D:\Drawings\Main Building Lower
> Level\Wound Healing\Version10 WHC Drawing Package.dwg
> FATAL ERROR: Unhandled Access Violation Writing 0x80282 Exception at
> 332be15dh
> 02/05/2003 at 09:44:34.703 Drawing: D:\Drawings\Main Building Lower
> Level\Wound Healing\Alt Location For Wound Healing.dwg
> FATAL ERROR: Unhandled Access Violation Writing 0x46795a6 Exception at
> 332be991h
> 02/05/2003 at 10:24:10.859 Drawing: D:\Drawings\Main Building Lower
> FATAL ERROR: Unhandled Access Violation Writing 0x805bd Exception at
> 332be706h
> 02/05/2003 at 11:04:19.968 Drawing: D:\Drawings\Main Building Lower
> FATAL ERROR: Unhandled Access Violation Writing 0x4c081275 Exception at
> 332be811h
> 02/05/2003 at 11:21:18.500 Drawing: D:\Drawings\Main Building Lower
> Level\Wound Healing\Wound Healing Center.dwg
> FATAL ERROR: Unhandled Access Violation Writing 0x8044a Exception at
> 332becebh
> 02/10/2003 at 11:10:35.140 Drawing: D:\Drawings\Main Building Lower
> FATAL ERROR: Unhandled Access Violation Writing 0x80426 Exception at
> 332becebh
> 02/10/2003 at 13:39:21.109 Drawing: D:\Drawings\Main Building Lower
> Level\SFMC-LOWER-1998.dwg
> FATAL ERROR: Unhandled Access Violation Writing 0x80480 Exception at
> 332be703h
> 02/10/2003 at 13:57:42.515 Drawing: D:\Drawings\Main Building Lower
> Level\Wound Healing\Wound Healing Center Drawing Package.dwg
