AutoCAD Map 3D General Discussion
neilyj
Message 1 of 4 (179 Views)
Exprot joined and queried data to plain CAD
179 Views, 3 Replies
06-19-2012 05:15 AM
I'm finding Map particularly infuriating today......(more so than usual)...!!!!
I have connected to various shp files and then queried by circle to get my area of interest. I now want to "export" this data as plain AutoCAD entities but can't seem to do it with any success.
Can anyone point me in the correct direction...??
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
antoniovinci
Message 2 of 4 (177 Views)
Re: Exprot joined and queried data to plain CAD
06-19-2012 05:41 AM in reply to: neilyj
Hmm, sounds like you wanna joke with us, man: a power-user with 1630 posts is NOT allowed to ask this kind of questions.. Anyway, let's joke:
1] _MAPIMPORT those shapes
2] _MAPTRIM everything by circle
3] finally _WBLOCK the remaining objects, or SAVE AS dxf rel.12
neilyj
Message 3 of 4 (171 Views)
06-19-2012 05:57 AM in reply to: antoniovinci
1630 posts in total - but considerably fewer relating to MAP problems....!!!!
I've done the first 2 steps: it's getting the shp files data to a CAD format that's causing the problem -  I tried the _mapexportcurrentmaptodwg but nothing is getting exported.
EDIT - Just tried in  2012 and _mapexportcurrentmaptodwg worked fine on a local drive and have now tried in 2013 with a local drive which also worked fine.
Conclusion - probable network access issue causing the export to fail..??
neilyj
Valued Mentor
parkr4st
Message 4 of 4 (162 Views)
06-19-2012 07:23 AM in reply to: neilyj
after the connect and add by query. map explorer, right click the layer and export data to sdf.  you can then map import the sdf with create OD  to cad
