AutoCAD Map 3D General Discussion
sweeneypaul0
Message 1 of 5 (220 Views)
Accepted Solution
Exporting to SHP - Export a buffer class to a polygon SHP
220 Views, 4 Replies
07-22-2013 10:39 AM
Hello All
I have a series of polylines with a global width of 5m which I want to export to a polygon shapefile to represent in GIS. I realised if I create a shapefile of the polylines and then create a buffer of 2.5m on either side I can create my desired polygon. My question is how do I export this polygon to a shapefile. I have tried bulk copy but this just seems to revert the buffer back to a polyline shapefile . Any ideas
Regards
*Expert Elite*
Alfred.NESWADBA
Message 2 of 5 (218 Views)
Re: Exporting to SHP - Export a buffer class to a polygon SHP
07-22-2013 10:48 AM in reply to: sweeneypaul0
if you created the buffer objects with command _MAPFDOBUFFERCREATE  and so created a SDF-file you can either use bulk-copy to create a SHP (bulk copy is sometimes strange) or you can create a new drawing and use command _MAPIMPORT to import this buffer-sdf and the command _MAPEXPORT to create a SHP from that imported geometry/data.
If you have the buffered geometry created in another way, then let us know what type of geometry it is currently.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Valued Mentor
parkr4st
Message 3 of 5 (207 Views)
07-22-2013 12:11 PM in reply to: sweeneypaul0
Do you want an outer line of the polygon 5m wide or a ring polygon 5 m wide?  Line style will give the first, the afore mentioned the second.
*Expert Elite*
Murph
Message 4 of 5 (197 Views)
07-22-2013 04:00 PM in reply to: sweeneypaul0
If your polyline is closed it exports as a polygon. You can change it to a closed pline in the property palette.
Murph
Supportting the troops daily.
sweeneypaul0
Message 5 of 5 (183 Views)
07-23-2013 03:36 AM in reply to: Alfred.NESWADBA
Thanks Alfred i imported it as an .SDF then it exported to SHP , worked a treat.
Cheers
Announcements
Need installation help?
