HI,
I read the post for when this question was previously asked and do not understand it. I simply need to export all text BY LAYER in my drawing, preferably to a format that I can import into Excel. What is the easiest way to do this please? Thanks
Solved by braudpat. Go to Solution.
Solved by antoniovinci. Go to Solution.
Hello
1) Please do a standard selection with a Windows !
2) When asking for the Export Filename ...
21) Please navigate to the good folder
22) then write for example : wings.txt OR wings.csv
23) Question for the separator ---> ;
Is it OK now ?
Patrice BRAUD
Hello
You are happy so I am happy !
If you want to have always a routine loaded at anytime, please :
APPLOAD <Enter>
On the lower right of the dialog box, use the icon to ADD this "EXPORT-TEXT.lsp" to your ACAD environment/profil !
Quit ACAD, Relaunch and now "EXPORT-TEXT" is always loaded and ready to run ...
Patrice BRAUD
THANKS .... I think I did this correctly, now when I reopen AutoCAD it says this every time, is there a way I can tell it to stop asking me this?
Hello
YES it's normal because this folder is NOT an approved path for ACAD !
The easiest way to solve it ---> SECURELOAD = 0
or add this folder to secure ACAD folders ...
Patrice BRAUD
