AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Exporting Text by layer to an Excel File
25 REPLIES 25
Message 1 of 26
1883 Views, 25 Replies
HI,
I read the post for when this question was previously asked and do not understand it.  I simply need to export all text BY LAYER in my drawing, preferably to a format that I can import into Excel.  What is the easiest way to do this please?  Thanks
25 REPLIES 25
Message 2 of 26
antoniovinci
Command: _MAPEXPORT
adding the property "LAYER" as Object Data.
Let's suppose you have N layers: if you open the resulting shapefile in a Gis editor (e.g. Qgis) you can automatically split it into N indipendent sub-shapes, by layer, yielding N files .DBF loadable in Excel.
Feel free to upload here a small drawing of yours: I can demonstrate the above technique quickly, sir.
Message 3 of 26
in reply to: antoniovinci
thanks because I didn't understand a word you just said 🙂
Message 4 of 26
antoniovinci
You're right, man, I apologize for my wretched english 😞
In the attachment, you got the promised N=7 files .DBF, loadable in Excel.
Message 5 of 26
THANKS but hmm, I have 61 layers in my drawing, I was hoping you could show me HOW you did this so I can do it in the future, why were there only 7 files that you sent?
Message 6 of 26
I guess what I was hoping for was, for example, a list of all the p101, p123, p479 values etc...  in the 2005_probing_completed layer for all layers ...
Message 7 of 26
antoniovinci
Well, your drawing contains pure text in only 7 layers.
The other ones look like text, but they're block attributes.
If you _BURST them, you can get the following attachment: check it out, and if it's good for you, I'll describe how-to.
Message 8 of 26
wow, thanks so much!  this is exactly what I need ... and the "how to" would be great, thanks!
Message 9 of 26
antoniovinci
In Autocad Map:
  1. command _BURST (in order to explode the embedded block attributes into Dtext objects)
  2. command _MAPEXPORT => choose TEXT type => in the Data tab, select LAYER as Properties => save as SHP file
In Qgis:
  1. open up the brand new shapefile
  2. menu VECTOR => DATA MANAGEMENT TOOLS => SPLIT VECTOR LAYER => UNIQUE ID FIELD => choose LAYER
Message 10 of 26
obviously lol 😉  thanks again!
Message 11 of 26
braudpat
Hello from France
An other method with a Lisp/VLisp program that will generate an CSV/XLS file !
So after it's easy to sort by layer, by entities, by value, by anything ...
I use it often because DataExtraction is not always the fastest method to extract Text, MText, Attribute !?
Antonio is the King of MAP + QGIS !
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 12 of 26
antoniovinci
in reply to: braudpat
Not bad, Monsieur: would you please share with us your Vlisp..?
Message 13 of 26
braudpat
Hello Antonio
At your order !
This beautiful VLisp "EXPORT-TEXT" routine is from (gile) ! ... Thks Gilles !!
Patrice BRAUD
Message 14 of 26
antoniovinci
Merci beaucoup, mais... it doesn't work in my old Map2006 😞
Cambronne !!
Message 15 of 26
braudpat
Hello Antonio
It works on my MAP 2015, 2014, 2013, 2012, 2011, 2010 !
Do you reach the dialog box to specify the output filename ?
If YES, into the filename please write something like :  ANT.TXT
Patrice BRAUD
Message 16 of 26
antoniovinci
Well done, it works if I manually add the TXT/CSV extension..!
Message 17 of 26
braudpat
Hello
YES you MUST write .TXT or .CSV with the filename into the dialog box ...
It's a very small default of this beautiful routine from (gile) !
EXPORT-TEXT works on Texts, MTexts, Attributes . I like it !!
Patrice BRAUD
Message 18 of 26
Sorry for this most rudimentary question but how do I load and then run this program in AutoCad Map 3D 2015?
Message 19 of 26
braudpat
Hello
1) With your keyboard :  APPLOAD  <Enter>
Browse your PC, Select the file "EXPORT-TEXT.lsp" then Load then OK/Close
2) With your keyboard :  EXPORT-TEXT  <Enter>
And play ...
Patrice BRAUD
Message 20 of 26
thank you, I did as you directed and selected "ALL" and it said 1681 objects selected, I exported the csv file and opened it and this was the result, what did I do wrong?
”Boost
