AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Exporting shp file from AutoCad Map 3D 2012 x64
1 REPLY 1
stevenwhite
648 Views, 1 Reply
Started having a problem when I export out a line in AutoCad to a shapefile. ArcMap can't open because the files don't match and whne I try to read it in AutoCad, I get the same basic message.
There was a problem accessing the connection's schema information.
The file 'L:\REFERENCE_MATERIAL\New-Connects\BTMR-08-02-TEM.dbf' is corrupt or does not have the same number of objects as the file 'L:\REFERENCE_MATERIAL\New-Connects\BTMR-08-02-TEM.shx'.
1 REPLY 1
I would be careful using 14 characters as filename for a shape (it 's an very old styled format, used in times for dos with 8.3 filename-structure).
Then you should always remove the IDX-file if you transfer SHP-data between different software-packages.
And just to make sure, there are some applications that see differences between lower- and uppercase-characters in the filename. So if you have a file A.SHP, a.shx and a.dbf ==> the files are not recognized to belong together, they have to have the same letters for all three filenames (at least 3 files).
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
”Boost
