I have been exporting from DWG to SHP and to SDF for years....I have run into a situation where I am getting characters at the end of a legal description in my object data table.
Here is the strange part, out of the 76,032 property records in that table...the issue only shows up in 256 of these records.
I am using AutoCAD Map 3D 2014...It does not matter what I export to...SHP, or SDF...the charcaters show up.
I am attaching a pics to show what it looks like
as I don't have the data ... can you verify that only those objects have truncated data when the string is longer than 128 characters?
If you look to the SDF schema, how long is that field defined as maximum?
- alfred -
