AutoCAD Map 3D General Discussion
Active Member
todor.latev
Message 1 of 5 (1,202 Views)
Export SDF to ASCII /or XLS/
1202 Views, 4 Replies
01-02-2013 10:57 AM
Using Civil 3D 2012 x64
I have an SDF file which contains point objects with associated data table records
I'm trying to extract the data to xls file /or text file/
Once imported in Map there's the option to view data table, then one can go select all and copy/paste everyhing in excel
This would have been perfect if coordinates were exported too. Alas I end up with a rather useless table
Is there a way to convert an SDF file to xls file and preserve all the data records along with the geometry /xyz/ in the process?
for something SO BASIC there HAS to be a basic solution
Thanks in advance!
C3D 2015 x64, SP1, Win7 x64, 16Gb RAM
If you have not "imported" the SDF, but connected to the SDF, then you can create calculated fields as additional columns to the datatable. Then you can export again (or use copy&paste) to get a XLS including the coordinate-values.
(hope this video is a help, even it's German, if not, let me know)
- alfred -
Alfred.NESWADBA
Message 2 of 5 (1,200 Views)
Re: Export SDF to ASCII /or XLS/
01-02-2013 11:10 AM in reply to: todor.latev
- alfred -
Alfred NESWADBA
Active Member
todor.latev
Message 3 of 5 (1,195 Views)
01-02-2013 11:31 AM in reply to: Alfred.NESWADBA
Thanks Alfred, this worked!
Never seizes to amaze me though how simple things like this have to be researched and worked around to accomplish...
BTW - is there a way to use excel as an SDF viewer/editor?
Cheers,
Todor
Alfred.NESWADBA
Message 4 of 5 (1,192 Views)
01-02-2013 11:41 AM in reply to: todor.latev
As Excel is no GIS-tool/has no GIS-functionality, I don't think so.
- alfred -
Alfred NESWADBA
olivier.eckmann
Message 5 of 5 (1,181 Views)
01-03-2013 12:45 AM in reply to: Alfred.NESWADBA
you can import SDF with MAPIMPORT command and convert attributes data to OD.
Then you can export to SHP file with MAPEXPORT command. You can export OD AND AutoCAD properties like geometry (X,Y,Z,length, area, rotation...), layer, color... to attributes data
In SHP format, attribute data are stored in DBF file which can be opened and viewed by Excel. But don't modifiy and save back the DBF, because you can damage structure of data.
Olivier
