AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Export polygon with hole to shape file
12 REPLIES 12
Message 1 of 13
3497 Views, 12 Replies
I have a polygon with a hole in it. I want to export this exterior polygon to a shapefile. I want the shape file to display as a "donut" if you get my meaning.
The shape keeps coming in completely hatched ignoring the island within. Is there a way to do this with the 2008 software?
12 REPLIES 12
Message 2 of 13
Is it an mpolygon or polyline? If it's a polyline then first select the polyline and push the New Feature from Geography button. Make sure the polygon feature is checked out and right click > edit feature. From there select add and trace the inner polygon. I'm not sure what you mean when you are talking about hatching. If you are importing polygon shapefiles and checking the box to convert to polylines then you will lose your ability to have the donut that you want. One reason I hate polylines. A line is not a polygon and hatch's are a pain. Can't say that the mpolygon is great either because they are harder to edit.
Message 3 of 13
I would go with the MPOLYGON command, I have used it with no trouble.
Message 4 of 13
I used mpolygon but by doing that I lose data attached to the object? Any ideas?
Message 5 of 13
If you had created your mpolygon from two closed polylines by first selcting the center polyline there should be no issue with exporting with an island. Here is the command line of what I am referring to when creating polygons with islands for export.
Command: mpolygon
Specify start point or [Fill/Select objects/eXit]
Message 6 of 13
Thanks John, I can do the island polygons, but my concern was mostly about the data. The closed polyline has object data attached to it. When I convert it to mpolygon, there is no more data. I couldn't find anything about that subject too.
Message 7 of 13
I see the same thing, when the polyline is converted to Mpolygon the object data is deleted. I was able to go back and re-attach the object data to the polygon after conversion and export as shp. Fortunately the object data table still existed but just not attached.
The polygon shp came in with the center island and the object data.
John
Message 8 of 13
John how did you reattach the previous data to it? I was able to attach the object to it, but had to reenter the data.
Thanks for all the help.
Message 9 of 13
I had to pass the data in the polyline to a centroid but still had to manually retrieve it. I am not aware of an automated way around this yet when it seems there should be a better solution. I will continue to look.
John
Message 10 of 13
Jfactory
I hope it's okay to bump an old thread if I have something new to suggest. I made a pizza (sticking with the food theme here) then:
I clicked on Split Feature ('mapfeaturesplit')
Command: _mapfeaturesplit
Select one or more linear or polygonal features to split:1 found
There are 1 checked-out features selected for split.
Create new or multi-part [New/Multipart]<New>:n
Generate new feature ID or use existing [New/Existing]<New>:n
Would you like to Draw or Select the line for split? [Draw/Select] <Draw>
Specify start point:
Then I traced around the donut hole I prepared earlier.
It makes a new feature in the middle of the pizza. Then I selected that feature and deleted it and voila, a donut!
Tags (3)
Message 11 of 13
antoniovinci
in reply to: Jfactory
Well, I missed this topic, but here's a classic way without juggling.
If you wanna get a donut shape with embedded OD, the magic answer is: "topology".
Message 12 of 13
shyamjeeme
I wanna to select more than a polyline at a time for update their xdata by autolisp. I am able to do it one by one but it is lengthy and time consuming.
Message 13 of 13
scheel
in reply to: shyamjeeme
Look at this link https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-AutoLISP/file...
There you will find the description of the ssget-function to select more than one entity.
When you use the filter option you can select only ploylines. But be carefull, there are more then one objecttype for polylines (POLYLINE and LWPOLYLINE).
(ssget "_W" '((-4 . "<OR") (0 . "POLYLINE") (0 . "POLYLINE") (-4 . "OR>")))
For Filter lists you find more explanation under the following links:
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2017/ENU/AutoCAD-AutoLISP/file...
http://help.autodesk.com/view/ACD/2017/ENU/?guid=GUID-5CB54129-22A1-42B9-B97C-2D2F5597F90E
Thorsten
Thorsten Scheel
Contelos GmbH
”Boost
