AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Export pipe network to shp file
2 REPLIES 2
859 Views, 2 Replies
Does anyone know if it is possible to export a pipe network created in Civil3D (2010) to a shapefile. I have tried the 3D map export command, but it does not recognize the pipes as one of the options (point, line, text, polygon). Any help is appreciated.
2 REPLIES 2
rick-chappell
Export the pipe network to a SDF file first (from C3D export Civil objects to SDF).
jdupuis53511,
I have add-on software which can make that, so if you would like it I can do it for you. Send me DWG or LandXML, and I will return SHP (and DBF) file.
Send me on my mail:
d dot galic at studioars dot hr
Drazen
”Boost
