AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
export object data to microsoft excel
15 REPLIES 15
Message 1 of 16
17713 Views, 15 Replies
I have a object data table attached to many polygon.  In this table i have 2 line of data.  I want to export in a tabloid like microsoft excel.  I know autocad have a command to do this...
Thanks a lot for your help
15 REPLIES 15
Message 2 of 16
Alfred.NESWADBA
the way I know is:
  • save your drawing and close it
  • create a new drawing
  • attach the previous drawing with command _ADEDRAWINGS
  • query the objects from the attached drawing (command _ADEQUERY) and create a list as a result (instead of querying the objects into the active/new drawing).
Good luck, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 16
hence_the_name
another way is to export your objects to ESRI SHP including the object data (command: _mapexport). It creates a DBase file (*.dbf) for the attribute data. The file can be opened in EXCEL.
Rob
http://raumpatrouille3d.blogspot.ch/
Message 4 of 16
antoniovinci
Well, the quickest way to get your goal is probably this:
1] issue the _MAPVIEWTBL command
2] OK
3] select all the rows, and then CTRL-C
4] in Excel, paste them
Message 5 of 16
in reply to: antoniovinci
i have a problem like this issue...
i have more features with some data properties in their schema
like this
feature1  geometry, prop1 (string), prop2(string)    etc.... etc...
feature2  geometry, prop2 (string), prop3(string), prop4(string)    etc.... etc...
feature3 ......
so i like to have a table in wich i can view a complete report of all features whit their properties
a manual way to do this il opening all data  tables, selecting coping and pasting in excel... but i'd like to find a command or macro way to do this automatically
is there a way to do this by a query ? or better whit a spatial query ?
thanks to all !
Message 6 of 16
Alfred.NESWADBA
you can try to use _MAPEXPORT to create a SHP-file, select your objectdata tables to be included in export.
After that is done you have 3 files created, a SHP, a SHX and a DBF ==> open the DBF in e.g. Excel.
Is that what you were looking for?
- alfred -
Alfred NESWADBA
Message 7 of 16
in reply to: Alfred.NESWADBA
hi alfred
thank you very much for your answer
yes it could be a very good solution
but it does not work if i have only sdf geographical entityes in each feature. I've not defined any object classes, but only a schema and drawed geographical entities.
I'm an expert user in Autocad but i'm newbee in map, so i don't know if my metod is very good....
1) i've got cad drawings whit polilines and polygons,
2) i've created a query after having associated them,
3) i've exorted the queried entities to a sdf file,
4) i've modified the schema, adding some property data,
5) i've modified or added the geographical entities on each feature in the schema....
now i have to make a report of all the entityes in excel....
your method could be very good for me but it seems does not work whit sdf features....
-marco-
Message 8 of 16
Alfred.NESWADBA
Create a new drawing, us _MAPIMPORT to import your SDF and don't forget to create ODTables from the attribtive data in the SDF, then you can export as described.
And if you alread have SDF, you can open the datagrid for each sdf and use copy&paste or export (under options, button on bottom of grid-view).
Alfred NESWADBA
Message 9 of 16
neezo89
hi
how to creat the ode table from sdf file
it seems that the sdf when imported have a different language
Message 10 of 16
Alfred.NESWADBA
in reply to: neezo89
welcome @forums.autodesk.com!
When you have started _MAPIMPORT, selected the file to import the dialog appears showing the input layer in a list, the 4th column in the list is "Data" with content "<None>" for that layer, click onto that cell to make it active, you get a small "..." icon, click onto it and you get the options to convert the SDF-attributive data into ObjectData.
Sorry to not understand that, how can data have a languate (that's what I don't understand here).
HTH, - alfred -
Alfred NESWADBA
Message 11 of 16
neezo89
Many thanks alfred for your support
ok i did that
then i defined object data from MAP Setup menu and in the object data field i select the field target but nothing appeared
shall i have to creat table from the home menue? because when i tried that ( to open data table you need to have a map layer).
exactly what i need
i have a dwg with mutiple lines
each one for sure has a start and end (xyz)
i need this data in table
start     end
x            x
y            y
z            z
thanks
Message 12 of 16
Alfred.NESWADBA
I'm not sure that I understood your question?
From your words:
>> ok i did that
If you did _MAPIMPORT and followed my video you should not have to create a datatable, it should be created by the import!
What am I missing?
- alfred -
Alfred NESWADBA
Message 13 of 16
neezo89
Many thanks for your efforts, this is highly appreciated.
To put things in order
I will simplify my request.
I have a simple  cad drawing contains  a number of lines
I need to get an excel or text file that contains the start and end (x,y,z) for these lines.
can we go into steps.
Message 14 of 16
Murph_Map
Use the Data Extration wizard,
http://www.youtube.com/watch?v=glziAlsuAX8
Just select the start X,Y,Z and end x,y,z  for the lines under the geometry data.
Murph
Supporting the troops daily.
Message 15 of 16
neezo89
in reply to: Murph_Map
I would like to thank everyone for help and support
Mohammad Atieh.
Message 16 of 16
yes.. 11 YEARS later.. LOL... Thanks for posts.
”Boost
