AutoCAD Map 3D General Discussion
Distinguished Contributor
2 Kudos
Post 1 of 7
Export Map Feature to Shapefile
339 Views, 6 Replies
03-15-2013 04:45 PM
Hi everyone!
If found that sometimes I need to have shapefile ony with one type of attributes.
It's easy to do querry in data connect but somehow I didn't find a way to export querred objects to independede shapefile.
Any ideas? Thank you.
You can add to the map by query then export to SDF format just what you queried in.
If you need it to shp format you can bulk copy to a new folder.
194 Kudos
Post 2 of 7
Re: Export Map Feature to Shapefile
03-16-2013 12:33 AM in reply to: Vasily_BC
One way would be:
  1. in an empty drawing, _MAPIMPORT the shapefile with full Object Data
  2. save as INPUT.DWG and close
  3. in an empty drawing, attach the INPUT.DWG with the _ADEDRAWINGS command
  4. command _ADEQUERY
  5. build a boolean query like LOCATION:ALL AND DATA...
  6. in Query mode, choose "Draw" then "Execute Query"
Perform a Zoom Extents, getting the only querred objects, ready to be _MAPEXPORTed.
P.S.
You can split automatically a huge shapefile by attribute, with the opensource Qgis.
Valued Mentor
35 Kudos
Post 3 of 7
03-16-2013 04:21 AM in reply to: Vasily_BC
two more -  after you back up you original shp data just to be sure you can restart if all fails
1
after you query, save to layer  this does not delete any data but saves the current display of you data if you want it in another map.  this allows you to maintain one data file and display it easily using layer files to put the data in teh map in various queried results.  at the lower edge of the query window there is Options, save expression & load expresion.  Save your query expresson so you reload it later to rerun your query after changing data and resave to the layer file.
2
in windows explorer, find your shp file files and select them, ctrl c, ctrl v, leaving the pasted files highlighted, F2 and rename the pasted shp files to something like "LotsGT5acres.shp".  put that shp in a map, select and delete all lots <5 acres and check it in.  you now have a shp with those lots >5 acres only in the data.
dave
194 Kudos
Post 4 of 7
03-16-2013 05:19 AM in reply to: parkr4st
Well done, Dave, but in the second point you don't need to duplicate the shapeset in Explorer.
You simply _MAPIMPORT the original shape, _QSELECT by Area > 5 acres, finally _MAPEXPORT of _Previous selected objects to a brand new .SHP
Valued Mentor
35 Kudos
Post 5 of 7
03-16-2013 07:36 AM in reply to: Vasily_BC
Yes, works also.  And there is also bulk copy for the adventurous.  Let's see what the OP can get done with the info so far and add help as needed.
Dave
2 Kudos
Post 6 of 7
03-16-2013 09:30 AM in reply to: antoniovinci
Thanks for replays! I would say this is traditional method, but is there a way to do it through Data Connect?
For me Data connect is a little bit more easer process, especially for querry. There possibility to export in some formats, however not in shp.
207 Kudos
Post 7 of 7
03-16-2013 05:44 PM in reply to: Vasily_BC
Murph
Supportting the troops daily.
