I want to export features (.STRING, .ROTATION, .X, .Y, BLOCK ATTRIBUTES...) from severals dwg drawings in txt file . In the same time and in the same result, I want to transform coordinate in NAD83 to Lat/Lon. If it's possible, I want to execute in a batch file, without open Autodesk Map.
I know that you can do a query in Map to extract file text but it doesn't take coordinates change...
With this txt file, I want to create a database to load in mapguide.
so ...have you got any idea ???
Thanks for helps!
Yannick
