Map 2012
How do I add text labels to points?
I'm exporting DWG objects to a SDF file. Once connected to the SDF file, text items are displayed as points as expected. I have ensured the STRING attribute is present in the conversion and I can see these values in the Properties pallete.
I want to label the points using the Style Editor but try as I might no text label appears. I've checked the obvious stuff like ensuring I'm not using black text on a black background and the text is not so small that I cannot see it.
I can label lines so I know I can do it!
Solved by Alfred.NESWADBA. Go to Solution.
Instead of _MAPCONNECTing it, try to _MAPIMPORT the SDF, setting up as the attached one...
Thanks, but I don't want to re-import something I've just exported.
If it comes to it then I'll have to XREF in text objects but surely there's a way to label them ??
have you activated the "object-label" property in the stylization-dialog for the SDF?
- alfred -
I'm a dummy. I was trying to label a line or polygon, not the point. Thanks for the help, your screenshot showed me my obvious mistake.
