AutoCAD Map 3D General Discussion
Valued Contributor
Neil47
Message 11 of 13 (126 Views)
Re: Export Cogo Point Nested Data
04-17-2012 12:33 AM in reply to: tpcc79
It's strange that you're having the same problem as Alfred. If it helps I have tried both Map 2012 and Civil 2010 both on Win7 64bit
The query will not draw the cogo point but does find the annotation templates in the dwg file. When I set the query to report and set the query as shown below the fields write correctly from the attached drawing file.
This morning I did
Current Query
AND Property: LAYER = PLI-WUG
Report Template
:LOCATION@stringer
:Att_8@stringer
and the report generated
Woleebee Creek,WOL-FF-W-0008-1149
Active Member
tpcc79
Message 12 of 13 (123 Views)
04-17-2012 06:29 AM in reply to: Neil47
Yes it is very strange that you are able to do it. I'm running Civil3D 2012 onXP  32bit. I have tried using 'blank' drawing templates, still with no success
Valued Contributor
Neil47
Message 13 of 13 (118 Views)
04-17-2012 07:12 AM in reply to: tpcc79
Does the cogo point display if you do Quick View after attaching? It displays for me. As a test, also run -purge to get rid of any regapps to see if anything is getting in the way of the query
