AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
export alignment to shape file
10 REPLIES 10
Message 1 of 11
rdawson
4375 Views, 10 Replies
I am running C3D 2009 with Map
Can anyone help me export a C3D alignment with ticks and stations to a shape file?
10 REPLIES 10
Message 2 of 11
in reply to: rdawson
Either export to SDF then convert it to shp format or export it to AutoCAD
dwg format then use the map export tool.
Murph
www.map3d.wordpress.com
wrote in message
news:6240674@discussion.autodesk.com...
file?
Message 3 of 11
rdawson
hmmm...I have tried both to no avail. I am sure it's user error
Message 4 of 11
In Civil 3D, with the menus, File > Export > Export Civil Objects to SDF.
The map export does not work with civil 3d objects you have to use the
export C3D objects to SDF.
Murph
wrote in message
news:6240723@discussion.autodesk.com...
Message 5 of 11
rdawson
perfect-thanks. How about the ticks and stationing?
Message 6 of 11
The sta and ticks are in the style used for that alignment, not a part of
the alignment that gets exported. That's where you need to convert the C3D
objects to a standard AutoCAD dwg then use the map export to create a point
type sdf/shp file.
Murph
wrote in message
news:6240839@discussion.autodesk.com...
Message 7 of 11
rdawson
thank you for all of your help!!
Message 8 of 11
O.Maille
4 years on and this is still a terribly over complicated process
Message 9 of 11
Murph_Map
in reply to: O.Maille
How so? One is a design software the other a simple geospatical infomation software file format.
Murph
Supporting the troops daily.
Message 10 of 11
O.Maille
in reply to: Murph_Map
It is over complicated as C3D has always been marketed for its integration with GIS through Map3D and alignments are barely more complicated than 2d polylines.
Message 11 of 11
Alfred.NESWADBA
I don't know any GIS-system that can store or handle curves/spirals of type Clothoid or Bloss, do you now any single system that can do that? Then please let me know which one that is!
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
”Boost
