AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
export a surface to use in arcmap
4 REPLIES 4
MKH-VB
510 Views, 4 Replies
I have a map with contours (polylines), at the correct elevations. I am needing a surface to use in arcmap. I can create a surface from contours in civil3d. Not sure how to get that surface to map3d or esri arcmap. Any help with workflow will be greatly appreciated.
mkh
4 REPLIES 4
Murph_Map
in reply to: MKH-VB
Export the polylines to shp with the 3d option. Then in ESRI use the surface tools on the contour lines.
Murph
Supporting the troops daily.
MKH-VB
in reply to: Murph_Map
what would i select in the data tab to get this to export correctly? Thanks
mkh
antoniovinci
in reply to: MKH-VB
Nothing, sir.
MKH-VB
in reply to: antoniovinci
thanks
mkh
”Boost
