I have a map with contours (polylines), at the correct elevations. I am needing a surface to use in arcmap. I can create a surface from contours in civil3d. Not sure how to get that surface to map3d or esri arcmap. Any help with workflow will be greatly appreciated.
Solved by Murph_Map. Go to Solution.
Export the polylines to shp with the 3d option. Then in ESRI use the surface tools on the contour lines.
MKH-VB wrote:
what would i select in the data tab to get this to export correctly?
Nothing, sir.
