AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Exploding an XRef
2 REPLIES 2
29161 Views, 2 Replies
Exploding an XRef
Hey all. Here's the rub: it seems that in in autocad 2004 it is no longer possible to explode and XRef to add the objects to a drawing permanently. Now, if I try to explode an XRef, it says: 1 found, 1 was an external reference. It then defaults back to a blank command line and does not explode the XRef. We are currently using ncopy from express tools to skirt this issue, but it will only allow you to do one object at a time. Any ideas? Ryan
2 REPLIES 2
Why don't you just insert the file you were xrefing and explode it on insert? Baically you are treating the xref as a block. -- Charles C. (Tripp) Corbin III, MCP Associate Vice President, GIS/Mapping Keck & Wood, Inc. www.keckwood.com (678) 417-4013 (678) 417-8785 fax "Ryan Rayda" wrote in message news:4017ef9a$1_2@newsprd01... > Hey all. > > Here's the rub: it seems that in in autocad 2004 it is no longer possible > to explode and XRef to add the objects to a drawing permanently. Now, if I > try to explode an XRef, it says: 1 found, 1 was an external reference. It > then defaults back to a blank command line and does not explode the XRef. > We are currently using ncopy from express tools to skirt this issue, but it > will only allow you to do one object at a time. Any ideas? > > Ryan > >
Hi Ryan, You can just use the XREF Bind option and convert the Xref into a regular block in AutoCAD. Then user the explode command and you will be able to use the objects in their native state. Regards Rakesh Ryan Rayda wrote: > Hey all. > > Here's the rub: it seems that in in autocad 2004 it is no longer possible > to explode and XRef to add the objects to a drawing permanently. Now, if I > try to explode an XRef, it says: 1 found, 1 was an external reference. It > then defaults back to a blank command line and does not explode the XRef. > We are currently using ncopy from express tools to skirt this issue, but it > will only allow you to do one object at a time. Any ideas? > > Ryan > > -- AutoCAD customization for Engineering/Mapping/GIS Get GeoTools @ http://www.4d-technologies.com/geotools Build MyGeoTools @ http://www.4d-technologies.com/geotools/my_geotools.htm FREE downloads : http://www.4d-technologies.com/techcenter
”Boost
