Why don't you just insert the file you were xrefing and explode it on
insert? Baically you are treating the xref as a block.
Charles C. (Tripp) Corbin III, MCP
Associate Vice President, GIS/Mapping
Keck & Wood, Inc.
www.keckwood.com
(678) 417-4013
(678) 417-8785 fax
"Ryan Rayda" wrote in message
news:4017ef9a$1_2@newsprd01...
> Hey all.
> Here's the rub: it seems that in in autocad 2004 it is no longer
possible
> to explode and XRef to add the objects to a drawing permanently. Now, if
I
> try to explode an XRef, it says: 1 found, 1 was an external reference. It
> then defaults back to a blank command line and does not explode the XRef.
> We are currently using ncopy from express tools to skirt this issue, but
it
> will only allow you to do one object at a time. Any ideas?
> Ryan
