AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Exploding a block with Proxy Objects
20 REPLIES 20
Message 1 of 21
5629 Views, 20 Replies
I have a block that is made up of poly lines on two seperate layers. When I explode the block it just disapears and when I tried to go into block editor mode it says
Block contains proxy objects.
Cannot edit block in Block Editor
Any idea how I can get to these lines?
I am using AutoDesk Map 2007
when I do edit block in place i get the message
** AcDbZombieEntity objects cannot be edited in place.
** At least one object must be selected to edit a reference **
Any ideas? The block is topograghy lines and I need the poly lines so I can import it to ArcGIS to is the 3D analyizer to create a cross section. But I cant do anything in GIS with a block.
20 REPLIES 20
Message 2 of 21
my kneejerk reaction:
have you tried using the AECtoACAD tool... (is that the right name?) that
should create a copy of the drawing, preceding drawing name with ACAD*, and
that drawing should then have aec objects turned into 'dumb' entities.
I don't have 07 installed here, so I'm not quite sure where this is located,
perhaps near save as or export?
Melanie Perry
***not all who wander are lost***
http://mistressofthedorkness.blogspot.com/
wrote in message news:5379883@discussion.autodesk.com...
mode it says
Message 3 of 21
I did a bet of research on the aectocad command and it seems like the way to go except
aectocad
or
-aectocad is an unknown command
I am thinking that it is only for vanilla cad and for some reason not a reconized command in Map 3D?
Message 4 of 21
if it's not then, try downloading the cui tool made available for 2006.
(i'm using map06 right now, and have this tool on my toolbar)
http://mistressofthedorkness.blogspot.com/2006/03/2006-can-turn-aec-objects-into-basic.html
Melanie Perry
wrote in message news:5380681@discussion.autodesk.com...
go except
aectocad
or
Message 5 of 21
That seems like it might work but I didnt see a link to download the cui file. Also my work internet here blocks blogs, so if you have a direct link or a link to something that isnt a blog that would save me the time of having pull out my laptop and then emailing myself the downloaded file.
Message 6 of 21
hmm, rereading shaan's blog, it looks like the cui file is already included
with the install?
Load the provided CUI located in C:\Documents and Settings\user\Application
Data\Autodesk\AutoCAD 2006\R16.2\enu\Support\AecArchXOE.cui
You can also use the command or script it from the command line.
Command: -ExportToAutoCAD
File format: 2004
Bind xrefs: Yes
Bind type: Insert
Filename prefix: ACAD-
Filename suffix:
Export options [Format/Bind/bind Type/Prefix/Suffix/?] :
You can easily script the command to batch convert DWG files.
Now I am headed back to Amsterdam to catch a flight back home after a few
days here in nice and warm Europe. I had a great time and will publish more
photos of my trip after I return home.
Melanie Perry
wrote in message news:5381511@discussion.autodesk.com...
Message 7 of 21
Yeah I read that but I dont have that cui on my system. I found AecArchXOE.dll and when i loaded that it didnt have any toolbars
Alltho the -exporttocad command works so i think it might be built in to 2007 but I would like the other tools. And the exporttocad command doesnt solve my orginal problem of removing the proxy objects in the block
Message 8 of 21
hmm, well, it was my assumption that it would, I'm sorry I was wrong.
Melanie Perry
wrote in message news:5381592@discussion.autodesk.com...
Message 9 of 21
not a problem. I think I may just end up re-digitizing the lines by hand if I cant figure this out
Message 10 of 21
The AEC2ACAD would have to be ran in the version of software that created
the "objects" IIRC.
One thing you can try is see if you can wbock the objects out then when you
insert them into a new dwg use the expolode method on insertion. Might work
might not. (?) Also you are checking and making sure all layers are on nd
visiable after you explode the first time right?
Murph
wrote in message news:5381714@discussion.autodesk.com...
Message 11 of 21
You wrong ? Nah just misinformed.
Murph
"melanie stone" wrote in message
news:5381665@discussion.autodesk.com...
Melanie Perry
Message 12 of 21
gee... if'n I only knew any good trainers to edjumacate me. 😜
Melanie Perry
"Murph" wrote in message
news:5381887@discussion.autodesk.com...
Murph
Melanie Perry
Message 13 of 21
I am sure nothing is turned off after the first xplode
When I try to wblock I get the message
Wblock operation rejected due to a proxy object that does not allow copying.
Message 14 of 21
Can you post a copy of the dwg in customer files?
http://discussion.autodesk.com/index2.jspa?categoryID=39
Murph
The world is not FLAT so why is your GIS data?
http://mappingitout.blogspot.com/
wrote in message news:5382011@discussion.autodesk.com...
Message 15 of 21
Here is the file
Its saved from AutoDesk Map 3D 2007 if anyone needs it saved as an older version to give it a try let me know.
Message 16 of 21
To me it looks like it was created in Land Desktop 2005. If you give me a
while I might be able to explode it down to standard AutoCAD objects and
post back if you don't have access to LDT.
Murph
wrote in message news:5383296@discussion.autodesk.com...
Here is the file
Message 17 of 21
I don't have LDT just MAP
If you can explode it down I would appreciate it.
Message 18 of 21
See if this works for you.
Murph
wrote in message news:5383444@discussion.autodesk.com...
Message 19 of 21
Yes! That works great, can you explain how you did this?
Message 20 of 21
I wblocked just the topo block out thern saved that as a R2004 format ,
opened it in LDT 2006 and saved as an AutoCAD dwg using the export to
AutoCAD drawing.
Murph
wrote in message news:5383610@discussion.autodesk.com...
”Boost
