my kneejerk reaction:
have you tried using the AECtoACAD tool... (is that the right name?) that
should create a copy of the drawing, preceding drawing name with ACAD*, and
that drawing should then have aec objects turned into 'dumb' entities.
I don't have 07 installed here, so I'm not quite sure where this is located,
perhaps near save as or export?
Melanie Perry
***not all who wander are lost***
http://mistressofthedorkness.blogspot.com/
wrote in message news:5379883@discussion.autodesk.com...
I have a block that is made up of poly lines on two seperate layers. When I
explode the block it just disapears and when I tried to go into block editor
mode it says
Block contains proxy objects.
Cannot edit block in Block Editor
Any idea how I can get to these lines?
I am using AutoDesk Map 2007
when I do edit block in place i get the message
** AcDbZombieEntity objects cannot be edited in place.
** At least one object must be selected to edit a reference **
Any ideas? The block is topograghy lines and I need the poly lines so I can
import it to ArcGIS to is the 3D analyizer to create a cross section. But I
cant do anything in GIS with a block.
