I have no problem with plingen staying on. Most likely you have the wrong
scaling set on the linetype. When you set your linetype through the linetype
manager on the Standard Toolbar, there is the button to Show details. If you
click on it you are given the option to use paperspace scaling units or
model space. This caused me to almost give up on using plot map sets till I
figured that out. Check out some of the map areas at this web site. There
all done with a customised plot map set. It doesn't take long. One morning
and all the maps are updated. True they are crude and the base maps don't
quite jive with polygons but that is in the lack of quality in the
bases(free).
Mike
http://www.gov.sk.ca/enermine/geomines/saskmap.htm
"James Solberg" wrote in message
news:FB29B49876766D2EEC3977C953ADCE64@in.WebX.maYIadrTaRb...
> I agree with Neil, and will add that when Map clips the map to a boundary
> for a page, the ltgen for polylines is turned off, so if you use a
> non-continuous linetype for hydro, winding roads, etc. you're screwed. It
> also won't clip blocks, as I recall, so you either get all or nothing. Map
> sets is kind of like the new COGO in Map 6. Looks good to list as a
feature
> in the advertising, but is useless in practice.
> "jessica" wrote in message
> news:f127939.-1@WebX.maYIadrTaRb...
> I am having trouble using the plot map set feature of map 5. I am new to
the
> "mapping" part of this all. Can I get a SIMPLE explination on using plot
map
> set, i.e. how and what to define, or is there something better out there?
