AutoCAD Map 3D General Discussion
Active Contributor
douglawson3952
Message 1 of 4 (427 Views)
Executing Query during zoom
427 Views, 3 Replies
03-31-2010 12:50 PM
I have a county wide aerial image in jp2 format, connected through Data Connect and everytime I pan or zoom it says "executing query". It is very slow getting around in the drawing (tracing over tree line, roads, etc.). I have a Windows 7 64-bit machine with 6 GB of RAM. Is there a setting I can turn off to make zooming, panning, changing layouts, etc. faster?
Doug
Active Contributor
KrakowiAneczka
Message 2 of 4 (264 Views)
Re: Executing Query during zoom
10-13-2011 04:50 AM in reply to: douglawson3952
I've got the same problem.
Have you found a solution to it?
Thanks!
Active Contributor
daniel.queiroz
Message 3 of 4 (200 Views)
05-09-2012 12:02 PM in reply to: douglawson3952
Everytime I zoom in or out, Map 3D Executes a Query and it takes a couple of seconds.
Has anyone come to a solution to this issue?
Thanks!
Daniel Queiroz
Technical Specialist
Autodesk Latin America
Autodesk do Brasil Ltda.
Rua James Joule 65 - 4o andar
CEP 04576-080 - São Paulo/SP
Valued Mentor
parkr4st
Message 4 of 4 (189 Views)
05-10-2012 02:07 AM in reply to: daniel.queiroz
That is normal behaviour.   Map is querying the raster connected to the drawing which takes time depending on your hardware speed, graphics card, file size etc.  the zoom send the coords of the new zoom area to teh inage and retrieves that portion with the query and then displays it.
inserting the graphic  with _mapiinsert puts the image into the dwg and it works faster because it does not have to query when zooming.
a query takes about 1 to 2 seconds on my computer with the image sizes i work with, (SID s in the 500 to 1000 KB range) zoom the inserted image about 1/5 of that
read up on hardware acceleration and 3dconfig.   those may provide you some things to check
